94 lt1 mystery
Old Aug 14, 2007 | 06:16 PM
schoppa's Avatar
94 lt1 mystery
Here's the story -
94 z28 runs fine - randomly stumbles & dies - will not restart (by ignition or popping the clutch while coasting).
Will easily restart with starting fluid sprayed in the throttle body & then clears out and runs fine again.
Pattern repeats about once every 15-30 mins
No codes.
Fuel filter changed.
Fuel pressure constant at 40-41 psi (even during/after stalling episode).
No dependence on temperature or rpm before stalling.
Question seems to be what could cause the injectors to shut down, but then refire fine when the engine is cranked with starting fluid? Any signal to the PCM that could do this? One of the opti signals?
Any help/suggestions appreciated - before my car gets rammed in the back in Houston traffic!
ChrisFrez
Nov 23, 2014 10:33 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
OneBad98Z
Aug 6, 2002 03:23 AM
kevkop94TA
Jul 19, 2002 09:56 PM
