94' LT1 in a 96' Car
I found a 94' Motor semi built up that comes with ECU and all wiring.
I wanted to put it in my 1996 Impala. Will the ECU be the same?
Wiring Harness?
Will the emissions ****'s be able to tell?
What other mods would I need to do ?
First time Poster but long time LT1 owner
any help is appreciated
thanks
Wiring Harness?
thanks
Originally posted by SkAchilles
Its OBDI when you have an OBDII harness, it can be done but it will be a bitch and wont pass emissions. Find a 96 like I did and it will be a lot more smooth.
EDIT: Just read you had an Impala. You will need to install a second knock sensor in the block if it doesn't already have one. If you have a tach right now, it won't work correctly with the 94 PCM.
Please excuse my ignorance.
But does the 94 block have a crank sensor ?
I need to pass emissions, So I guess the best way is to keep the 96' ECU and harness. What will need to be added or modified to do this ?
New Mexico doesnt have the strictest emissions laws.
94 doesn't have crank sensor, 96 does..
96 also has a different timing cover [the 96 opti is vented, and the crank sensor is in the 96 timing cover]
Blocks are the same.. just swap the timing cover? then use the hub and balancer off the 96, and the vented opti too?
[I am not positive that the B body is the same as F body, you should verify that first..]
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
