94 iroc w 350Lt1 - drove it in changed plugs, wires,cap & rotor- no start.
Old Jun 9, 2011 | 03:20 PM
threedz's Avatar
Question 94 iroc w 350Lt1 - drove it in changed plugs, wires,cap & rotor- no start.
Don't get it, after a basic t/up had a no start. rechecked and replaced cap rotor, and plugs and still notta. Fuel press good 47 psi, no codes but shows iac wide open and map at max. pulled map and pulled vaccum on map with vac pump, sacnner readings read correctly and car started and ran ok so but put map back in and won't start. shows only about 4" vac (manifold) while cranking. checked for vac leaks with carb spray and found nothing. wow is'ts a mystery to me. there is no cat and it ran fine coming in so what has happened? This is the opti distributor behind the water pump - so in order to change cap and rotor, had to pull the w/p. Is it possible antifreeze has contaminated the distributor? The dist. does not appear to be wet inside and everything looks fine in there. This distributor has key so can only go in oneway. Any ideas out there?
APPRECIATE ANY THOUGHTS OR COMMENTS YOU HAVE, CHEERS
Old Jun 9, 2011 | 04:35 PM
CharlzO's Avatar
Re: 94 iroc w 350Lt1 - drove it in changed plugs, wires,cap & rotor- no start.
I assume you mean 94 Z28? When you say no start, how is it cranking? open spin, sputtering, start n stall? I know it sounds silly, but have you double-checked the plugs for order, and ensured everything is set up straight?
Old Jun 9, 2011 | 06:19 PM
TedH's Avatar
Welcome to the board. You should place your questions in the appropriate tech forum for better responses, however I am going to ask if the plug that goes into the opti from the top is all the way in (clicks)?
Old Jun 9, 2011 | 09:47 PM
AdioSS's Avatar
West South Central Moderator
94 IROC?
Old Jun 10, 2011 | 06:24 AM
AL SS590 M6's Avatar
Moderator
Welcome to the site.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
PCLZ28
Dec 24, 2015 05:19 PM
Fatdog2
Feb 13, 2015 08:19 PM
Jazsun
Dec 29, 2014 12:14 PM
