94 corvette non vented to 95 camaro vented
Old Aug 13, 2009 | 10:04 AM
JC95Z's Avatar
I go the deal of a life time on a lt1 with 30k miles,It came out of a corvette.I have a 95 camaro with a vented system.I know to do the full conversion id have to change the cam, timing cover ect. Can i just use the non vented opti in my car until i do a cam swap later? It was a complete engine.I've read alot of articles and it looks like the vented system is designed to keep the moister out. Any timing differnces?
Old Aug 13, 2009 | 11:33 AM
You would need the opti harness off the 94, if you intend to swap the whole thing in. No timing differences. The vent system does help to remove any moisture and ozone created inside the opti.
Old Aug 13, 2009 | 11:43 AM
JC95Z's Avatar
Awesome it came with the wiring harness so im good to go there.i noticed the crank hub is dif too the one for the corvette is alot thicker and the belt wouldnt line up.Should i just unbult the 3 bolts and switch harmonic balancers or change the whole thing.I know some years had the dif size keyways.
Old Aug 13, 2009 | 03:40 PM
You'll need to use your hub and pulley for your accessories. The 'vette uses slightly different spacing. LT1s don't use a keyed hub.
Old Aug 14, 2009 | 10:59 AM
JC95Z's Avatar
Found out the vette also uses a different intake and fuel rail. It doesnt have the notch or cut out in the intake where the fuel rail sits flush on top. question...what gave the corvette 300 hp compared to the 275 in the camaro? Is it the heads,intake,cam? Im gonna have to use my old intake to use my fuelrail.DID they use the same #injectors?
HectorM52
Jul 30, 2017 11:46 AM
ChrisFrez
Dec 7, 2014 06:01 PM
CaRParts102
Dec 6, 2014 08:45 AM
Dec 4, 2014 11:56 AM
thenewkid
Nov 27, 2014 09:41 AM
