94/95 A4 shift kit mod
Old Oct 27, 2003 | 05:56 PM
jeffwood's Avatar
has anyone done this mod : http://members.***.net/chipsbyal/page/trans/page3.html
Old Oct 27, 2003 | 07:50 PM
95Z28QFZ's Avatar
Works great........ It seems to change the shift points of the transmision and the shifts seem to be a little firmer.
Old Oct 27, 2003 | 08:02 PM
Hotwire's Avatar
I've got it on my truck and love it. I also have pcm4less tuning, Bryan made the performance shift mode rock solid, like having a full race tranny when performance mode is activated.
best thing about that, I can hit the button, get jerked around by the tranny, then when I get tired of it, I can turn it off, unlike shift kits that you install in the valve body.
good luck.
Old Oct 27, 2003 | 11:53 PM
S8ER95Z's Avatar
good luck.
Yeah..sometimes hitting 2nd gear scatches while driving normal is just annoying...
Old Oct 28, 2003 | 07:56 AM
Re: 94/95 A4 shift kit mod
If you search for "performance shift" you will probably find lots of info.
Old Oct 28, 2003 | 08:32 AM
Hotwire's Avatar
lol, you should try it in a light azz S-10, somtimes can be dangerous!
Old Oct 28, 2003 | 06:20 PM
jeffwood's Avatar
does it make shifts firmer AND more comfortable?
Old Oct 28, 2003 | 06:27 PM
Hotwire's Avatar
?? define comfortable.
When activated it it holds the gear till higher up in the rpm range and "stiffens" the shifts so it's like dropping the clutch in a manual. turn it off and it's like your normal everyday daily driver.
it makes the shifts like installing a shift kit, although w/ the shift kits, you can't turn them off like you can the performance mode.
Old Oct 28, 2003 | 07:35 PM
jeffwood's Avatar
does it make downshifts a bit different? im always clunking into 1st gear when taking a 90 degree turn that i have to brake through.
Old Oct 28, 2003 | 09:43 PM
It does make some changes to downshift timing, but not when TPS is at 0%. In addition, 2>1 shift timing is not changed at all in performance mode at any TPS percentage.
If you have Tunercat or LT1_edit, you could experiment with the 2>1 timing if you wanted.
stangspank
Nov 13, 2015 01:02 PM
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
RedLineRev
Jan 23, 2003 03:51 PM
