93z28 starts then shuts down
My 93 has new plugs wires, distributor, water pump, computer has been sent for R and R. Wmen we got the computer back the car ran better then ever and 2 weeks later the car started its issues. I know it says to make sure the VATS is turned off and i have no idea how to shut it off if it is even on. I checked for wiring issues and found some chewed wiring from some mice. I also found out some idiot bypassed the cars stock sec urity system with a Viper Alarm and have alarm Pod for it.
Can Some one please tell me what is going on with this car.
thanks Paul
Car Is for sale $2000 on craigslist in St Louis (for Pics)
thanks Paul
Re: 93z28 starts then shuts down
It sounds like you have a lot of issues
First get all your wiring fixed
Then get on shbox.com and verify your opti coil ignition module vats ect trust me he has the info
You need to sort out your ride
If not well I live 12 miles from six flags in the washington/pacific area so maybe I can lend a hand?
thanks Paul
I live 12 miles south of De soto rite by Washington State Park. Let me know if you want to come out and take a look at it.
Has it ever started and run normally? Did this problem just start?
When it starts, how long does it run before it shuts off? Have you checked the fuel pressuer?
Have you scanned it for codes? Very easy on a 93, since you can still use the paperclip to short the pins and flash the codes on the SES light.
the only thing i can think of is wires or security system issues my self it says to make sure the VAATS is shut off but does not say how too.
Does the fuel pump power up when you apply 12V to the fuel pump prime connector next to the ECM? That bypasses the ECM permit and the relay.
Courtesy of Shoebox:
http://shbox.com/1/fuel_pump_prime.jpg
Not sure what you are "ohming out" on the fuel pump sending unit. The level sensor doesn't have anything to do with the pump running.
You indicate "there are no codes flashing"..... do you at least get "12" to indicate the ECM has gone into diagnostic mode?
Magenta_Hearts
Mar 29, 2017 08:54 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jan 23, 2015 01:13 PM
fpete1992
Dec 11, 2014 03:51 PM
