93 z28 LT1 throttle body gaskets - where can i find them?
Old Apr 25, 2010 | 08:46 PM
solaris_vii's Avatar
pretty much what the title says, im about half way through a rebuild on my 93 lt1 throttle (it needed a hefty cleaning after 182000 miles) and i cant seem to find a gasket set for it. everyone i find is for 85-92 throttles, they look similar but i want to make sure i order the right stuff. anyone know where to get a set? thanks in advance
Old Apr 25, 2010 | 08:57 PM
Shoebox has the answer for the manifold gasket, about 2/3 the way down the page, on the left side:
http://shbox.com/1/Parts.htm
1993-1997 Throttle body to intake manifold gasket - 10105379
But the part number for the top and bottom plate gaskets is only for the 94-97 throttle bodys.
Old Apr 25, 2010 | 11:00 PM
Though not specifically listed in the parts book, I think the top/bottom gasket kit would work on a 93.
Old Apr 26, 2010 | 05:29 AM
Is it possible the 93 bottom plate is a bit different, to accomodate the screw-in type IAC valve? Not sure.... just a thought?
Old Apr 27, 2010 | 08:49 PM
just talked to the guys at tpi parts and they said the kit for the 85-92 tpi throttle would work. the only difference is the top plate on 93 lt1s got a rubber gasket where as the tpi throttles had a paper gasket. im fine with a paper gasket so i went ahead and ordered one next purchase is an aluminum throttle plate to replace that garbage plastic one. thanks for the help guys! i think im finally done with this throttle rebuild, on to the alternator
Old Apr 27, 2010 | 10:31 PM
Comparing the two exploded views on my site, the bottom gasket sealing area looks pretty much the same. That was what I was basing my opinion on.
Old Apr 28, 2010 | 10:12 AM
i can get you a picture of the bottom of the 93 throttle body if someone has a pic of the 94+ we can compare them and know for sure if its interchangeable. let me know if interested.
Old Apr 28, 2010 | 12:02 PM
I don't know that a picture is necessary. The exploded views are already on my website (unless they differ from the actual, but I doubt it).
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
