93 z28 check engine
Old Nov 28, 2005 | 05:08 PM
scottsales's Avatar
93 z28 check engine
My 93 has a check engine light on. Scan tool says code 26. Troubleshooter has no data for a code 26
Old Nov 28, 2005 | 05:26 PM
Re: 93 z28 check engine
DTC 26 for a 1993 =
Quad-Driver Module (QDM) #1 circuit
applies to:
- AIR pump relay circuit
- EGR solenoid
- EVAP solenoid
It can be any of the above things, but my money is on a blown AIR pump fuse.
Old Nov 28, 2005 | 05:38 PM
Pampered-Z's Avatar
93s had a service bulletin for this. The wire from the fuse box to the air pump is to small a gauge wire and burns out. The bulletin is just to replace with a thicker gauge wire. If you have a volt meter check the wire ( think it's white ).
Old Nov 28, 2005 | 08:25 PM
Jeff H's Avatar
Check to see if the AIR pump fuse or fan fuse is blown. If so, check your AIR pump if you still have it. One of the AIR check valves went bad on my old 93 and it let exhaust back into the AIR pump. The warm air built up condensation and filled the AIR pump with water. It eventually froze one winter night and blew the fuse. Your pump might be seized or one of the fans could be having problems.
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
cmdeshon
Jan 4, 2015 11:15 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
cmdeshon
Dec 27, 2014 10:06 AM
