93 z iat sensor reads 317 deg F ?
Old Nov 27, 2005 | 01:07 PM
Fbody1's Avatar
Question 93 z iat sensor reads 317 deg F ?
my freind has a 93 z , the car runs ( could run better) his only mods are mac headers, cai, hypertech stage 2 chip, when we scan the car ( scanner from jegs,actron)the air intake temp reading starts off normal(just after starting the car) at whatever the outside temp is, or close to it, then it keeps going up , does not matter if you sit still w/car at idle , or drive down the road? also the fuel trim BLM's are at 108 , anybody had this before or any ideas to the cause of this? has not set off any codes, we replaced the ait sens w/new still the same
Old Nov 27, 2005 | 01:25 PM
OBE1 95Z28's Avatar
Re: 93 z iat sensor reads 317 deg F ?
If you BLM's are at 108, they're pegged on the rich side and your part throttle performance and fuel mileage is going to suffer. Not sure if your AIT is affecting your BLMs. I see Tunercat in your signature; does that mean you tuned it yourself?
As far as the IAT readings I'd double check the wiring but definitely wierd if the temp starts out normal.
Old Nov 27, 2005 | 01:54 PM
Alvin@pcmforless.com's Avatar
Sounds like a datalogging definition error. I see it all the time
The IAT can only read up to 160F which is about 7Xish in celcius.
Old Nov 27, 2005 | 04:22 PM
Fbody1's Avatar
no it's not my car it is a freinds 93 z and I have not tuned it. was thinking that his scanner was wrong ,or it was the hypertech chip he has in it, if it is a datalogging error what and how should we do about it? and we have checked the wiring to the ait sensor
Old Nov 27, 2005 | 04:38 PM
Use a better datalogger Its not the tune..
TTS datamaster, Tech 1 & 2, are my favorites for OBD1 cars. HP tuners has a awesome scanner for obd2 (off topic)
Old Nov 27, 2005 | 04:40 PM
Let me go on to say that the computer doesn't suppport anything higher than 160ish F.. so no matter what type of failure wiring or sensor.. you cannot report that high of IAT
Old Nov 27, 2005 | 05:36 PM
Fbody1's Avatar
will the ait sensor have an effect on the BLM's being 108
Old Nov 27, 2005 | 05:42 PM
OBE1 95Z28's Avatar
It may be true that the computer won't do anything above 160F, but I've seen my Scanmaster display an IAT of 212F.
HectorM52
Jul 30, 2017 11:46 AM
HarleyZ28
Oct 5, 2015 06:23 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Drag Bear
Jul 22, 2002 05:38 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
