'93 Z egr delete
Old Mar 26, 2010 | 08:43 AM
plattted's Avatar
'93 Z egr delete
Can I unplug the vacuum lines and plug them, leaving the EGR valve in place?It seems that the EGR is "coming on" at 1800RPM to 2200RPMs, affecting the engine by rough running in that speed range.
GM's hot cam, 1.6 rr's adj F.P. regulator and 52mm T.B.,Tuned by PCM for less.
Any suggestions would be appreciated.
Old Mar 26, 2010 | 11:07 PM
Not an "Advanced Tech" topic...... moving.
Old Mar 27, 2010 | 09:19 AM
Yes, the valve will act as a block off plate as long as it is sealing properly and no vacuum is supplied to open it.
Old Mar 27, 2010 | 10:56 AM
plattted's Avatar
EGR delete
Thank Rob B. Your clear, concise answer is appreciated.
Just what one would expect on such a great site!
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
tnmotown
Aug 10, 2015 11:52 PM
