93 LT1 oil pressure switch
Old May 12, 2010 | 11:04 PM
Rugermk2's Avatar
Hi,
I'm going to try to replace my oil pressure switch tomorrow. Any ideas on how to put it back on or what tools i will need? it was very easy to take off, because the only thing still in the motor was the plug with threads. Any ideas? Thanks for looking
Old May 13, 2010 | 07:03 AM
An oil pressure sensor socket is recommended. Though on a 93, it is in an easy place to access, so your choice of tools is more plentiful.
Old May 13, 2010 | 07:49 AM
19z28camaro02's Avatar
Be advised. There are two different switches for the LT1, but your car only has 1. There is a 1/8 thread switch and 1/4 thread switch. Make sure you know which one you have. The one that uses 1/8" also uses an adapter fitting. A 1/4" thread switch will work no matter what if you have this adapter and do not use it. If your car came with the 1/4" switch, you cannot use the 1/8"
Old May 13, 2010 | 07:50 AM
wrd1972's Avatar
Socket is about $6 or so. Its just an extra deep well metric. Do not overtighten it. Snug works well.
HectorM52
Jul 30, 2017 11:46 AM
Z28countrymama
Jan 22, 2015 02:50 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jul 4, 2005 05:00 PM
