93 lt1 chugs lean 1500-2200 cold
Old Nov 21, 2006 | 08:15 PM
lukej54's Avatar
93 lt1 runs great after 15 minutes of driving but chugs back fires out of intake when cold, idles fine just will not run 1500-2200 range cold.No codes replaced opti,plugs,wires,o2,map,prom,ecm,coil and fuel pump all injectors are with in limits k&n intake edlebrock headers.Again the car is a strong 13.80's runner just will not run cold start up any help thanks.
Old Nov 22, 2006 | 05:15 AM
Possibly a problem with the coolant temp sensor not telling the ECM the correct engine temperature. If the ECM doesn't know how cold the engine is, it can't apply the correct cold start A/F enrichment.
oldschool
Feb 9, 2016 09:21 PM
Gtpguy
Jan 26, 2015 04:50 PM
Jan 23, 2015 01:13 PM
Jessie4tin
Jan 7, 2015 08:53 AM
