93 lt1 in 97 v6 help !
Old Aug 23, 2007 | 06:33 PM
carrylr's Avatar
I installed a 93 lt1, trans (700r) and computer out of a Trans Am into my 97 v-6 camaro. The camaros OBD2, and the TA OBD1 but the motor harness plugged right into the harness on inside of the firewall.I was told that the chip in the key was matched with ecm so i also pulled the ignition lock cylinder and installed that in the column. When i turn the ignition switch on all dash lights come on but i can't hear the fuel pump, or relay cycle to pressure the system. when i hook the snap on scanner to aldl it says no communication.I am not getting any spark either. any suggestions ?
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
