93 intake manifold options.
Old Jul 25, 2010 | 07:02 AM
xxteenobesexx's Avatar
I am building Blown 383 93 formula. I just purchased an intake manifold that is 94 plus. I was going to port it, but I want to make sure that I can use the 94 w/ m y speed density setup.
http://speeddensity.org/showthread.php?t=679
I doubt I can use it but lemme know if i am wrong!
Old Jul 25, 2010 | 07:42 AM
To clarify, I Have a 94 manifold w/ fuel rails that I got for 50 bucks. I would like to know if I can use this manifold (w/ the batch fire rails) with my setup. basically will all of my crap bolt up and run right. Id like to put together my motor before I pull the old one.
also, can a tpi throttle body be used on a 93?
Old Jul 25, 2010 | 07:57 AM
bw_hunter's Avatar
It bolts on just fine. You'll have to 'adjust' the fuel lines as they attach at a different spot and the FP regulator is at a different spot but it won't make a difference. You'll either have to switch to the 93's injectors or re-tune to use the 94's larger ones.
people have switched to speed density with 94+ cars and have no issues...you can as well.
Now the question. Why are you bothering? You can port your 93 manifold easily enough and I doubt the 94+ manifolds offer higher performance over your '93 parts....
Old Jul 25, 2010 | 09:10 AM
96capricemgr's Avatar
My understanding is the 93 rail is restrictive compared to the 94+ so not only can you do this but the higher capacity rail may be of benefit on a blown stroker.
On the other hand the 93 intake doesn't have the crossover trough right behind the TB so it might be slightly better.
Old Jul 25, 2010 | 10:19 AM
The 93 rails are designed for "batch flow" hydraulics. The 94 and up rails are designed for "sequential flow" hydraulics. There's a significant difference in the pressure profile when you are pulsing 4 injectors at once, vs. pulsing the one at a time. Whether you will notice a difference will only become obvious after you build it and can inspect the plugs, looking for differnces in the A/F ratio from cylinder to cylinder.
Old Jul 25, 2010 | 01:12 PM
The cylinder to cylinder balance on a stout LT1 is so poor to begin with I doubt using a rail designed for one stock system vs the other would improve anything. I was talking total volume flow.
Besides the LT1 goes into batch at WOT rpms anyway. It is sequential at low idle and cruise rpms.
Old Jul 25, 2010 | 02:53 PM
First time I've ever heard that.
Old Jul 25, 2010 | 02:55 PM
I have a set of 42 lb injectors in the garage still in the package. I also am going to have my car retuned anyhow because I am going from stock to 383 procharged.
My 93 lt1 is running and in my car. My 383 short block is sitting on a pallet in my garage. I want the least amount of down time for my car, so if I assemble my 383 before I even drop my 350 lt1, i wont be waiting on the Intake manifold to get ported. My friend are kinda flaky, so when I drop the Engine we can just start putting in the other one.
Old Jul 25, 2010 | 02:59 PM
I was thinking of new rails anyhow.
It doesnt have the trough for the x over
Thanks!
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
