93 camaro dyno
Old Feb 24, 2004 | 08:17 PM
shox9879's Avatar
93 camaro dyno
248 rwp only power adders are cai, headers, and borla is this good or should it be higher for stock?
what could i do to get a little more
Old Feb 24, 2004 | 08:19 PM
blazzinbird's Avatar
I would think your numbers would be higher, maybe time for a good tuneup
also was it a dynojet or a mustang dyno
Old Feb 24, 2004 | 08:21 PM
Fastbird93's Avatar
Yeah, that's a bit low. I'd be looking more for near 300 HP. How old are the major ignition components, O2's ect. How was the A/F ratio?
Old Feb 24, 2004 | 08:25 PM
shox9879's Avatar
dyno
i think dynojet
really the car has about 72,000 miles
and plugs&wires,opti @ 50,000
Old Feb 24, 2004 | 08:27 PM
There is something wrong there then, you should be around 300 to the wheels
Old Feb 24, 2004 | 08:30 PM
shox9879's Avatar
93 dyno
do you think its my fuel system
Old Feb 24, 2004 | 08:34 PM
truedualws6's Avatar
For a 3,600 pound car and a 13.35 you should be
about 300 rwhp.
Old Feb 24, 2004 | 08:35 PM
it could be a bad o2 sensor, clogged cat, fuel filter, low fuel pressure, and number of things
when the car is running do you smell gas at all
ZaneO's Avatar
Well, my guess is that the converter is eating up a little power, but not much.
You should be around 270-280.
Did you get A/F readings from the dyno or do you have cats?
Old Feb 24, 2004 | 08:39 PM
shox9879's Avatar
no cats
do you think it could be the posi unit\
Old Feb 24, 2004 | 08:41 PM
no the posi wont affect it
Old Feb 25, 2004 | 08:10 AM
IDOXLR8's Avatar
There is something definitely wrong with your car. One of the best mods for a 93 is an AFPR. I picked up 10 rwhp and 17 rwtq with this mod. I would say you should be around 280 rwhp with the mods you currently have.
Old Feb 25, 2004 | 08:38 AM
street demon2k3's Avatar
which AFPR did you use IDOX, and at what setting? any mods?
Old Feb 25, 2004 | 08:59 AM
IDOXLR8's Avatar
The best way to adjust your AFPR is on a dyno. I think if remember correctly my car made the most hp with the fp set at 41 psi. Also I was running a Hypertech AFPR.
Old Feb 25, 2004 | 10:40 AM
Indy93Z28's Avatar
I dyno'd 247rwhp w/just CAI in my '93 so something is definitely off...
