93-96 rear main seal on a 97 car?
Old Sep 17, 2007 | 04:48 PM
rasputin's Avatar
In trying to take out my rear main seal today and replace it with a new one, I noticed that the aluminum part where the seal sits was from a 93-96 car (10088158). Would that cause any problems to put that on a 97 block/car? Or do I need to buy a 97 rear main seal (12554314)?
Also, how in the hell do you get the seal off? The little tabs where you are supposed to put a flat head screwdriver to pop it off wont work.
thanks for the help.
Old Sep 18, 2007 | 02:09 AM
jclark311's Avatar
Yea its the same seal, remove the seal housing, and beat that seal out with a screwdriver from the inside out, clean the housing, and tap in the new seal, using a pieace of wood the size of the seal.
Old Sep 18, 2007 | 06:38 AM
He's not going to want to remove the housing if he is not taking off the pan.
Keep trying on the slots. It should eventually come out.
Old Sep 18, 2007 | 02:12 PM
G. McDonald's Avatar
Check the seal housing bolts
While you are at it, you might want to check the bolts holding the rear main seal housing to the back of the block. Mine were only finger tight when I took mine apart. I don't know why. Best of luck.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
The Seer
Nov 20, 2014 06:32 AM
97 RedSS
Jun 10, 2003 07:58 PM
