93/94 whats the difference???????
Old Feb 23, 2004 | 09:38 PM
street demon2k3's Avatar
i picked up a 93 t/a ws6(conversion) on TT2's and need to know whats the difference between the 93 and 94 models other than the MAP & MAF sensors? also how loud is the borla w/out plates, rate 1-10? how loud is it compared to a cutout under the pass. seat?? thanks for any info guys
Old Feb 24, 2004 | 05:11 AM
slopokrodrigez's Avatar
93's where 22lb injectors and were batch fired. 94 switched to 24lb injectors that are sequentially fired. Therefore the computer is different in a couple of ways. The 93 computer can have the PROM changed out for programming. The 94 has to have the computer flashed since the PROM can not be removed.
The O2's now went to heated 3 wires from a 1 wire design in 94. I also believe the 94 was the first year for skip shift on the manuals.
Old Feb 24, 2004 | 06:28 AM
Mtrhds94Z's Avatar
All you ever want to know about the difference.. and then some..
http://web.camaross.com/forums/showt...993+difference
WobblySausage
Oct 7, 2015 02:44 PM
NewsBot
Sep 30, 2015 04:20 PM
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
