911!Help ASAP! Middle of Header install
Old Feb 27, 2004 | 07:14 PM
1.8ttolt1's Avatar
i am in the middle of installing rksport headers in a 94 camaro and the drivers side won't go in without removing the steering shaft but i don't know how to remove it. the install i read didn't say anything about removing it but i don't see any other way of getting it in. i already remove the one bolt that seems to attach the steering joint, but i can't seperate it. anyhelp would be appreciated.
Old Feb 27, 2004 | 07:34 PM
97 RedSS's Avatar
There are 2 bolts(I believe 10MM?) that hold the linkage together..Remove them and get under the car and tap up on the linkage to slide the collar off the shaft..
Cody
Old Feb 27, 2004 | 08:29 PM
1.8ttolt1's Avatar
I only see one bolt on the steering shaft. Is the other bolt at the steering gear coupling?
Old Feb 27, 2004 | 09:33 PM
1.8ttolt1's Avatar
HELP PLEASE!!!!!!!!!
Old Feb 27, 2004 | 09:39 PM
dkeers's Avatar
There is one bolt at the top and one at the bottom. Undo them and the steering linkage comes right out.
Dustin
Old Feb 27, 2004 | 09:42 PM
97 RedSS's Avatar
Its down by the Kmember..you will have to get the other one from under the car...
Cody
Old Feb 27, 2004 | 09:46 PM
97 RedSS's Avatar
$300 and Ill fly out to CA
Cody
Old Feb 27, 2004 | 10:08 PM
Fastbird93's Avatar
If it helps, when I put in my ASM headers, the steering shaft had to come out, but I got everything out from the top. One bolt at the top of the shaft, one at the bottom, and a good rap with a hammer set it free. Cake after that. Just be patient with it.
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Jlo
Feb 23, 2015 12:20 PM
dmcdonald96
Jan 30, 2015 06:46 AM
NewsBot
Dec 30, 2014 09:40 AM
NewsBot
Dec 28, 2014 06:20 PM
