#8 Spark plug Removal??
Old Mar 23, 2007 | 09:19 PM
MyWifesZ28's Avatar
All right people...what's the trick for removing the #8 plug...better yet how about running the plug wires around all that sh...stuff in the way.
Your tips are greatly appreciated!
Thanks.
Old Mar 23, 2007 | 10:27 PM
Razor_Blade's Avatar
#8, I get from the bottom by putting a spark plug socket on it and turning it with a wrench. If your arms are big, you might have to drop the starter.
Old Mar 23, 2007 | 10:45 PM
Kainzien's Avatar
Yeah I've had to do it with a wrench and it takes forever.. I zip tied my wires out of the way and put heat shields on the wires closest to the headers..
Old Mar 24, 2007 | 02:52 AM
zlighting's Avatar
Here is the trick... (Without dropping the y-pipe)
  • Get your car up on ramps.
  • Disconnect the battery terminal.
  • Remove the 2 starter bolts, and move the starter aside.
Now you can easily get to the 3 rear spark plugs on the passenger side, save a lot of time and Band-Aids too!
Old Mar 24, 2007 | 03:18 AM
Heatmaker's Avatar
Advanced Member
Thanks.
You want the trick? Drop it off at the dealer and pick it up in an hour when it's done.
Old Mar 24, 2007 | 11:35 AM
2000GTP's Avatar
True, but I think the dealers caught on. From some of the posts on here, the dealers and shops are charging a good amount to do a LT1 plug change.
Old Mar 24, 2007 | 12:52 PM
AXEMAN's Avatar
Before I put my headers on I could reach my #8 by putting my hand behind the oil dipstick and just going to it that way. Not real hard at all. And no I am not the worlds smallest guy (6' 2'' 210lbs).
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
