7k rpm ???
7k rpm ???
Alright im wondering if my setup can handle 7k rpm. The Setup is as follows:
Comp-R lifters
Trick Flow Chromoly 5/16 P-rods
Comp Pro Magnum 1.6 Rockers NSA
CC306 cam
Guideplates
EX612 springs w/ lightweight chromoly retainers (~120/380 pressure)
Ferra Valves
Stock shortblock
So can the engine handle it, if not then what is the weakest link? Im not sure about the pushrods and am thinking about going with standard CC hardened ones.
Thanks,
Stu
Comp-R lifters
CC306 cam
Guideplates
Ferra Valves
Stock shortblock
Thanks,
Stu
It will handle it, for a little bit.
The 306 will make power up there, it's a topend cam. How many miles on the shortblock? And you might want to spring the oil pump for more pressure. That will help ya out anyway.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
