7 mpg help!!!!!!!!!!
Old May 6, 2007 | 01:07 AM
pugads650's Avatar
i recently purchased a 94 camaro from tmorgan800 and it runs great but it is soooo bad on gas. the mods the car has include a lt4 conversion kit heads intake hot cam tes headers 1.6 gmpp roller rockers slp cold air intake lt4 knock module pcm for less tune and a tci 3500 stall converter.
tommorow im swapping out the stall converter and replacing it with a 1800 stock stall im hoping this will cure the gas milage but i doubt that it will give me an extra 7 mpg so what other type maitanance can i do and what are common gas miliage killers in these cars i would greatly appreciate any help you can give thanks.
btw yesterday i put 20 bucks of gas wich here in california 2 gallon haha j/k it was around 5.6 gallon and out of those 5.6 gallon i got exactly 38 miles. this here equates to 6.7 miles per gallon and im paying 3.69 a gallon .
jonathan
Old May 6, 2007 | 01:16 AM
NoRiceInside's Avatar
get off the gas pedal foo
Old May 6, 2007 | 01:27 AM
pugads650's Avatar
ive been driving like a old lady trying to save my gas but doesnt seem to work the needle just starts moving towards E.
Old May 6, 2007 | 01:51 AM
bombebomb's Avatar
O2's?
Old May 6, 2007 | 01:58 AM
pugads650's Avatar
i have no check engine light so i guess there still good.
Old May 6, 2007 | 03:11 AM
Asylist's Avatar
hell, that means your engine is running perfectly as can be. Your math must be off or something....although I suppose your check engine light could be burned out, but then the computer would let you know by lighting up the check engine light.
Old May 6, 2007 | 03:39 AM
pugads650's Avatar
the check engine light turns on when i turn the key but once the car is started it goes off.
Old May 6, 2007 | 08:14 AM
quick-z's Avatar
My car was running very rich recently and no check engine light was on. I had a mechanic look at it and he told me that the MAF sensor was dirty. He took it out, cleaned it, and the car is now running better and it's getting good mileage. I'd give it a shot. They sell MAF cleaner at most auto parts stores.
Old May 6, 2007 | 08:20 AM
Z-RATED94's Avatar
The TCI converter is not going to cause your gas mileage to be that bad. Wait, it is a lock-up converter isn't it? Anyways, find out what the real problem is, but still lose the TCI and get a real (good) converter.
Old May 6, 2007 | 01:51 PM
FryedClutch's Avatar
i dunno i really like my tci 3500 lock up stall
got the cc306
and i still manage 13mpg in the city
Old May 6, 2007 | 02:02 PM
2000GTP's Avatar
Sounds like something is mechanically wrong. Swapping in a stock stall converter is only going to set you backwards and most likely will not help your poor fuel economy issues.
Old May 6, 2007 | 11:20 PM
pugads650's Avatar
im almost done installing the new converter im hoping for 15-17mpg in the city and 20-25 mpg on the hwy i know im dreaming but it could happen hahahah.
Old May 6, 2007 | 11:25 PM
Craddock's Avatar
Since you have a 94 it could be having problems, just the engine not catching it. The 94 OBD I system isn't the best at catching bad sensors and such.
Old May 7, 2007 | 01:36 AM
Red on Red WS6's Avatar
I agree.
You need to get your car scanned and see what those sensors are doing. My bet is your MAF and or O2's are bad. Have you done a visual check to make sure you have no vacuum leaks?
Old May 7, 2007 | 01:42 AM
pugads650's Avatar
im hooking up the data logger tommorow but im new to the whole data logging thing so just tell me what numbers to post and ill do that tommorow thanks agian for the help ive gone thru 80 bucks of gas and have less than 100 miles on the car.
