6spd to auto
Old Apr 12, 2006 | 02:13 PM
JJFUGIEL's Avatar
6spd to auto
anyone heard of anyone switching from 6spd to auto? i've had manual for so long, i was thinking of changing it to auto to have somwething different. but noone seems to do this. or maybe someone has a low milage auto that they would want to swap out. thanks, jay
Old Apr 12, 2006 | 02:15 PM
hulettsz28's Avatar
Re: 6spd to auto
yea it is pretty uncommon. I have a ticking timb bomb of a 4l60e, stock, with 3.73 gears i will give to you as soon as it goes. lol. You would think it would be more common, as a built automatic with a torque converter proves to be faster than a manual at the track (quarter). I say go for it. put a good stall in there, do it. do it. do it.
Old Apr 12, 2006 | 02:35 PM
DiabloGT's Avatar
Re: 6spd to auto
i have a auto thats just about to hit 60,000 miles, how many miles does yours have?
Old Apr 12, 2006 | 02:37 PM
WS Sick's Avatar
Re: 6spd to auto
Mine has 86,000 and runs mid 11s all day long (1.6 to 1.7 60 foots)
Old Apr 12, 2006 | 04:58 PM
97WS6SCharged's Avatar
Re: 6spd to auto
Most people swap over to a th350/400 for drag racing. It's a bit of a pain since you need to change the radiator and run the transmission cooler lines. Other than that, a shifter, crossmember, flex plate and a computer tune are all you really need to swap to a 4L60E.
Old Apr 13, 2006 | 09:03 AM
roughneck427's Avatar
Re: 6spd to auto
Im going to do the same thing as far as converting to a A3 turbo 400 and ditch the 6 speed i dont see why you would have to change the radiator for a tranny cooler run an external cooler they work better anyways
Old Apr 13, 2006 | 09:07 AM
WS Sick's Avatar
Re: 6spd to auto
You could also just run a large stand alone cooler for the tranny so you don't have to replace the radiator.
Old Apr 13, 2006 | 09:10 AM
Chopstix's Avatar
Re: 6spd to auto
that is what I did..I do not miss my T56 at all
with a TH350-400 or a 700R4 you do not even have to retune....reccomended but not required
Old Apr 13, 2006 | 09:30 AM
Re: 6spd to auto
Sorry, you guys are correct on the trans cooler. I guess I'm losing my mind here lately.
Old Apr 13, 2006 | 09:43 AM
WS Sick's Avatar
Re: 6spd to auto
No , youre right ,if you want the factory look. But simply for conveinience you can run the seperate cooler.
Old Apr 13, 2006 | 10:09 AM
DIYAR21's Avatar
Re: 6spd to auto
l have an auto and l just rebuilt it.. it has 4k on it.. 4L60E
Old Apr 13, 2006 | 03:07 PM
Re: 6spd to auto
Please read the site guidelines on what to post on which forums.
You posted essentially the same topic (M6->A4 conversion) here on "LT1/LT4 Engine Tech" a couple days ago. I moved it to "Drivetrain" because that's where we post questions about transmissions. Now you've posted it incorrectly again here on LT1/LT4 Engine Tech.
http://camaross.com/forums/showthread.php?t=444350
Please post on the correct forum. Do not repost a topic.... simply add on to your original post, or if no one has responded, respond to your own post and type "TTT" for "to the top" putting your post back at the top of the forum topoic listing. No not do this more than once every 24 hours.
Parts Wanted
May 1, 2016 10:25 AM
drt
Sep 27, 2015 04:39 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
scottcba1
Sep 8, 2015 09:52 AM
tdigger9899
Sep 7, 2015 10:56 AM
