6,200 RPM miss
Old Feb 13, 2007 | 01:23 PM
  #16
mark94's Avatar
Sweetred95ta, The file is in your email. Thanks. Can also get it here.
http://www.savefile.com/files/475678
Tireburnin, It misses just as bad on the street as it does on the dyno.
Old Feb 13, 2007 | 06:41 PM
  #17
tireburnin's Avatar
That sucks to hear it isn't something easy. Have you thought of going down the route of an ignition box? I have graphs from early in the heads/cam days that look similar to your graph, but I ended up changing so many things at the same time I couldn't attribute it to one thing.
I changed wires, added an ign box, and loosened up the valve lash. Also went to a th400 but I doubt it was related.
Old Feb 14, 2007 | 09:51 AM
  #18
mark94's Avatar
What are you calling an 'ignition box'? The small module by the coil?
Old Feb 14, 2007 | 11:17 AM
  #19
tireburnin's Avatar
No I'm refering to an MSD or Mallory. The graph doesn't look very ignition related, but I've heard of stranger fixes.
Also back to basics:
Did you degree the cam?
Have you removed a spring to check one? I realize they are new, but?
Have you eliminated valve float as the cause?
Old Feb 14, 2007 | 11:21 AM
  #20
Sweetred95ta's Avatar
That doesn't look like valve float.
NewsBot
Mar 30, 2015 12:40 PM
DetroitZ28
Feb 13, 2015 07:33 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Redbird
Sep 15, 2002 07:41 AM
