Which 58mm throttle body
Just "eyeballing" it, I do believe my Holley 58mm throttle body is centered as compared to the stocker. I can tell you for sure that the AS&M 58mm throttle body is NOT.
With that being said, I believe the AS&M throttle body is of higher quality with less "issues" than the Holley.
Re: Which 58mm throttle body
Originally posted by quicksilver97ta
Which 58mm throttle body has the bores centered exactly over the stock location?
I have my intake off and plan to port it to 58mm from the stock 52mm openings. I dont have the 58mm throttle body yet though so I will simply take 3mm off all the way around each bore on the intake. I understand some aftermarket t.b.'s bores are off center and some are on center not sure which one(s) though. Any help in eliminating or selecting one will be helpful. Thanks in advance.
I agree with the first two statements-
none
People really need to get out of this "its stock so it must be restrictive" thinking. Our MAF, TB and intake manifolds dotn need much modifications for most guys
none
The AS&M TB has offset bores, and wont line up like stock. You should wait on porting until you decide on which one to get and do the porting once you have a gasket for the TB to match to the intake.
-Tony
-Tony
I beg to Differ, I never had any problems with my Holley, & the fact that its got closed off IAC passages makes a big cam / split blm issue happy, its also got a very very sexy look to it
Man, you must be VERY VERY lonely.
Thanks for the many replies. Sounds like the AS&M is the only one that is significantly off center. And if memory serves, I got that in my head a while back from reading Brent's install guide on f-body.org.I'd like to wait till I had the t.b. in my possesion but I dont know when that will be and It would be so much easier to port it now while the intake is on my work bench since I'm port-matching it with the heads.
Well, if you really want an AS&M, here is a scan of the gasket for you to use as a template
http://www.bfranker.badz28.com/misc/58mmgasket.JPG
As for my comment on Holley vs AS&M. You rarely hear of issues with the AS&M yet several people on here have complained about quality control issues with the Holley. The issues with my own Holley were minor in that all I had to do was grind a stud down to connect the cable. However, others have talked about seeing LIGHT around the blades even when fully closed!?!? How the heck that happens with a CNC machine is beyond me
I put a bbk 58 mm on my car recently. The increase is modest next to none from what I can tell. I bought it used for $150, so I said freek it. I figure I'll need it when I go with a bigger combo in the future anyway. I say don't waste your money on a new one, buy a used one. much cheaper
Originally posted by arnie
Hmmmm. Ya, that looks like the full size/actual size.
You might still be running in 640x480 or "Apple Font" for all I know
