58mm TB is not too big!
Old Apr 24, 2003 | 04:16 PM
96 TA's Avatar
Just installed on on my TA and I can feel a noticable gain. I know people go around and around about it being too big for bolt on LT1's. Im going to get it dynoed to see just how much I did gain. Later!
Old Apr 24, 2003 | 04:19 PM
Hopefully you have some "before" numbers to compare to (otherwise there is not much point). Post back the resuslts.
Old Apr 24, 2003 | 04:26 PM
twells's Avatar
yea, really let us know what you find out maybe put on your stocker for one or two pulls and then while it's cooling bolt on the 58. really though let us know
thomas
Old Apr 24, 2003 | 04:30 PM
Gripenfelter's Avatar
Slap on a 52mm TB and tell us if you feel a difference.
Old Apr 24, 2003 | 04:31 PM
96 TA's Avatar
Yes, I have nubers from befor I had the 58mm, ive changed nothing sense. Ill kept every one updated.
Old Apr 24, 2003 | 04:37 PM
96 TA's Avatar
Id do it if I had someone with a 52mm available. It's nice haveing one tho, it takes a lost less throttle to get the car moving! Pull's better up top and the throttle reasponse increase has made the car more reasponsive in the lower end. So Id have to say it improved preformance across the board. But only the dyno will show it.
Old Apr 24, 2003 | 04:44 PM
twells's Avatar
when do you think your have that beast on the dyno?
Old Apr 24, 2003 | 05:06 PM
Chrisbequick's Avatar
The feeling of a gain and an actual gain are two different things. A throttle body often feels like much more of a gain than it actually is, since for any given throttle opening you are moving more air. Essentially, you are effectively opening up the blades the same amount as before with less pedal movement. Throttle response is mighty impressive, but the gains often stop there.
I'm not saying you didn't gain anything. I'd just like to see the real results.
-Chris
Old Apr 24, 2003 | 05:18 PM
1997rblckSS's Avatar
All I noticed with mine is a crisper Throttle response...I mean it makes sense that no matter how much air you pump into the engine, the engine is only going to take what it needs.
Old Apr 25, 2003 | 09:41 AM
RTICWOLF's Avatar
OK, we have all read many posts about gains/no gains from a TB upgrade.
I know our 48mm TB's are good for at least 400 HP, right? I know I have read that from some of the best board members in the past. I too am curious if you see any gain.....
Now, I have a question.......I think I read on another post a while back that our intakes are already ported properly for a 52mm TB, just the gasket needs to be trimmed, is that correct?
Do you have to port the intake to use the 58mm TB?
I guess the reasons I am asking is that I was going to remove my TB and polish it (or have it polished ) but maybe I would rather buy a new one already polished and clean.
So, if you all were to buy one, which would you buy and which would you steer clear of?
Thanks everyone for all this great information on this board. It is really amazing the pool on knowledge here!
Old Apr 25, 2003 | 09:50 AM
danner's Avatar
I would stay clear of the Holley TB. Nice and shiny but tempermental. And to add, poor customer service unless you are buds with one of the techs.
Old Apr 25, 2003 | 09:53 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
i honestly cant justify paying $400 for a 58mm tb when the real restriction is in your heads.
doesn't matter how air you can get into the intake manifold if it cant get down the heads.
please do a before and after, I'm very currious
bunker
Jan 30, 2016 08:09 PM
truecontr3
Oct 11, 2015 09:30 AM
Sep 18, 2015 03:46 PM
NewsBot
Aug 3, 2015 02:40 PM
Louey
Pacific
Jul 27, 2015 09:58 PM
