58mm TB
Old Nov 18, 2006 | 06:37 PM
96camaroz281988's Avatar
58mm TB
hi i am wanting to get a 58mm TB becasue i can get one cheap and my LT 1 is stock would the 58mm be to big.
Old Nov 18, 2006 | 06:47 PM
MysticTeal95Z28's Avatar
http://web.camaross.com/forums/showthread.php?t=485080
Old Nov 18, 2006 | 06:57 PM
ya i read that but i was wanting to no if putting a 58mm Tb on a stock engine would be bad i will port the intake to a 58mm i am not going to leave it at 52mm.
Old Nov 18, 2006 | 07:33 PM
CamaroSS30thAnn's Avatar
on a stock motor its pointless.....its a waste of money for like 5hp and i hear the bigger throttle bodys make throttle response a little slower
if ur not putting out alot of power, its not worth it
Old Nov 18, 2006 | 07:38 PM
razor02097's Avatar
besides, the intake ports are only 52mm so even by putting a 58mm on you will only get 52mm out of it.
Old Nov 18, 2006 | 08:47 PM
speed_demon24's Avatar
A 58mm tb gives you so much more throttle response its not even funny.
Old Nov 18, 2006 | 11:11 PM
T/A-Bob's Avatar
hi i am wanting to get a 58mm TB becasue i can get one cheap ...
I might suggest you buy the thing (cheap), sell it for a reasonable price, then use the money for some different performance parts.
Old Nov 19, 2006 | 12:30 AM
RedsTA's Avatar
Honestly, the response is so much better with a 58mm tb. Get one, match your intake to it, and let the other mods begin. It will soon become an advantage to the mods you do next. If you can get one for a good price go ahead and pick it up. Some people say its not worth it, but after doing it, im a firm believer it helps.
Old Nov 19, 2006 | 10:48 AM
no need to laugh
thanks for correcting my mistake
Old Nov 19, 2006 | 11:03 AM
526 SS 96's Avatar
a 58mm on a otherwise stock car will loose HP and torque. It's not a bad thing to have for later mods. If you get a good deal on one, I would just leave it on the shelf untill you stock pile the other parts you want. Prove it to your self. Go to the dyno with your 58mm TB in hand. Test fit it before you go, so you don't waste an hour @ $100 each fitting your TB for the first time. Make a couple of passes with the set up as is, and while the car is cooling down change over to your new TB. 15-20 min later you can make a couple of more pulls get your results and make a decision based on that. If you are fast at swaping tb's you can get out of the shop for $100.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
bunker
Aug 1, 2015 09:47 PM
