58mm TB
Old Jun 13, 2005 | 06:41 PM
chuckd4more's Avatar
58mm TB
I did a search on TB and found a few problems with the BBK sticking/ high idles once warmed up. Has anyone had this problem with the Holly 58mm? Would there be any other brand recommendations?
Old Jun 13, 2005 | 06:52 PM
Fastbird93's Avatar
Re: 58mm TB
I don't know about the holley, but I fixed my BBK.
http://www.speeddensity.org/modules....iewtopic&t=100
Old Jun 13, 2005 | 07:42 PM
89TramsAmGTA's Avatar
Re: 58mm TB
On my Holley 58MM TB I found that the TPS spring return tab was rubbing against the throttle body. I just ground a little off the TPS tab. Works fine. Allen
Old Jun 13, 2005 | 07:48 PM
Quickshotkimber's Avatar
Re: 58mm TB
I have a 58mm BBK and used to have a problem with idle sticking. It turned out to actually be the pulleys in the traction control sticking. WD40 took care of it. I think you will be fine with a 58mm. You WILL need to be tuned for the TB
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
bunker
Aug 1, 2015 09:47 PM
