58mm tb
Old Feb 26, 2005 | 06:05 PM
besz28's Avatar
58mm tb
hello today i put on my 58mm tb, i ported the intake to accommodate the 58mm tb. when iam at idle the rpm's drop down to like 500-700 it almost sounds like it is going to stall. is this normal when going to a 58mm tb? do i need to get my car retuned? it is a 6 speed 1994 z28. thanks
Old Feb 26, 2005 | 06:28 PM
Re: 58mm tb
Did it idle correctly with the pcmforless prgramming BEFORE you put the 58mm TB in? What has he got the target idle speed set at? Did you set up the throttle stop screw correctly, to put your IAC counts around 40 and the TPS voltage near 0.65V at closed throttle? Are you sure the IAC motor is responding correctly? Everything plugged back in?
Old Feb 26, 2005 | 08:19 PM
besz28's Avatar
Re: 58mm tb
it did idle correctly before, i had a local custom tune done.not pcmforless,i will check those other things thank you
Old Feb 26, 2005 | 11:52 PM
Re: 58mm tb
Originally Posted by besz28
....i had a local custom tune done.not pcmforless....
....230/236 cam programming by pc for less.....
Old Feb 27, 2005 | 06:57 AM
besz28's Avatar
Re: 58mm tb
i haven't changed my signature yet.
Old Feb 27, 2005 | 03:30 PM
besz28's Avatar
Re: 58mm tb
connections look ok. ????
Old Feb 27, 2005 | 07:28 PM
besz28's Avatar
Re: 58mm tb
car is running awesome iam sure iam over the 400rwhp mark car hauls. thanks for the response injuneer, and no thanks for the other responses deadbeats
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
bunker
Aug 1, 2015 09:47 PM
