58mm monoblade
Old Mar 18, 2007 | 08:12 PM
96 SS 1424's Avatar
Question 58mm monoblade
Does anyone run an Arizona Speed & Marine 58mm monoblade? How do you like it? Would a stock engine with bolt-ons handle this with the computer program upgraded? I'm getting a ported and polished intake set up to take a monoblade or a twin blade. I will be upgrading the heads and cam in the furture, what would you recommend?
Old Mar 18, 2007 | 08:15 PM
mdenz3's Avatar
IIRC that manoblade TB flows 1300 CFM which would be WAY to much for your motor. Save your money, and after the heads and cam get a bigger TB if you need it, but even then you'll probably only need a 52 or 54mm.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
truecontr3
Oct 11, 2015 09:30 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
