58mm AS&M Throttlebody ????
Old Apr 9, 2006 | 11:46 AM
MYT30TH's Avatar
I was getting ready to install my new throttlebody and noticed that the IAC sensor port ( bottom port ) was threaded, as opposed to being a slip fit as the stock version on my 97 Z28.... Can somebody please give me a heads up on this.
Thanks in advance !
Bill
Old Apr 9, 2006 | 08:06 PM
67ProStreet502's Avatar
Re: 58mm AS&M Throttlebody ????
Just change out the bottom plate with your old one if you still have it. What you have on the new one sounds like it's for a 93.
Old Apr 11, 2006 | 03:26 PM
MYT30TH's Avatar
Thanks for the reply....unfortunately the stock IAC plate is not interchangeable with the AS&M 58mmm throttle body. I did talk with the guy's @ AS&M and they are going to swap it out for me.
Bill
Old Apr 11, 2006 | 04:00 PM
WS Sick's Avatar
I have the AS&M 58mm throttle body and I placed my stock IAC housing on it.
Old Apr 11, 2006 | 10:39 PM
OBE1 95Z28's Avatar
If you have a stock intake manifold, the 58mm opening will be blocked as the stock opening is only 52mm.
Old Apr 12, 2006 | 07:35 AM
MYT30TH's Avatar
Thanks for the input ...but I did port / gasket match for the 58mm AS&M Throttle body
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
bunker
Aug 1, 2015 09:47 PM
