58mm AS&M
Old Jan 14, 2006 | 09:20 PM
saxmo's Avatar
58mm AS&M
Hey guys, I have a basically stock LT1.. I have a 58mm AS&M throttlebody...30#SVO injectors.. a few performance parts, but nothing to really affect the horsepower. Would the 58mm be too big? If so, what size should I use?
Old Jan 14, 2006 | 09:24 PM
OBE1 95Z28's Avatar
Re: 58mm AS&M
Stay with the stock TB; even mildly modified engines won't really benefit from a larger TB.
Old Jan 14, 2006 | 09:27 PM
ss97dml's Avatar
Re: 58mm AS&M
the opening on the intake is only 52mm,you have to open it up to 58mm.
Old Jan 14, 2006 | 11:14 PM
LameRandomName's Avatar
Re: 58mm AS&M
Well, I wouldn't BUY a 58mm TB for a mostly stock engine, but you already have one.
You would need to open up the front of the manifold of course, and get your computer reprogrammed; although that's mainly for the 30# injectors.
In THEORY you can't have too large a TB on a fuel injected engine, but drivability may be an issue for you; and I'm talking about throttle tip-in.
Personally, I think you might be better off trading your 58 for a 52 and using that instead. It's still more than you need for your mostly stock engine, but less hassle in terms of the manifold issue.
Old Jan 15, 2006 | 10:19 AM
saxmo's Avatar
Re: 58mm AS&M
Thanks for the advice. When I bought the AS&M, I was gonna go pretty modded, but have decided to stay relatively stock. I guess, I need to try and trade for a 52mm now. Dwayne
Old Jan 15, 2006 | 10:28 AM
saxmo's Avatar
Re: 58mm AS&M
Does arizona speed and marine make a 52mm? I couldn't seem to locate one.
Old Jan 15, 2006 | 11:40 AM
OBE1 95Z28's Avatar
Re: 58mm AS&M
You won't see any benefit from the 52mm TB on a stock setup either as the TB is not limiting your power. Sell or trade your 58 for something you can use.
Old Jan 15, 2006 | 01:34 PM
Severous01's Avatar
Re: 58mm AS&M
i've got a 383 with a cc306 cam and i'm running a stock unit for now. it's not hindering mee too much, and i'm still making around 450 hp. when i get the new rockers and other gadgets on i'll swap over to a 52mm. the bigger ones are more for serious power or power adders.
Old Jan 15, 2006 | 02:54 PM
saxmo's Avatar
Re: 58mm AS&M
thanks for the advice.. I probably should sell it, and use the bucks for some kewl valve covers, or something. Thanks
Old Jan 15, 2006 | 03:00 PM
saxmo's Avatar
Re: 58mm AS&M
are the corvette TB the same as ours? I have option on new 1995 vette TB, but wanna make sure it'll work on our car.
Old Jan 16, 2006 | 09:28 PM
Severous01's Avatar
Re: 58mm AS&M
no, they and the 93 camaro's have a different TPS and throttle linkage. it won't work. you can makeshift it to work, but the effort could be spent somewhere else...like porting your heads
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
bunker
Aug 1, 2015 09:47 PM
