58mm BBK on a non 58mm intake
Old Mar 23, 2015 | 08:29 AM
maybe2fast's Avatar
I have my intake opening opened up mono-blade style, with a stock TB. I just purchased a 58mm BBK and dry fitting it on a spare stock intake there are the obvious 3mm lip all the way around. My question is...can I just use the 58mm until I redrill? I would essentially be using the intake as a 52mm with 58mm openings.
Old Mar 25, 2015 | 06:20 PM
bw_hunter's Avatar
Re: 58mm BBK on a non 58mm intake
No, the throttle blades will hit the smaller bore and could jam open....bad idea.
Old Mar 26, 2015 | 08:34 AM
maybe2fast's Avatar
It does not jam on the BBK, I put it on a spare intake that is unmodified. Works perfectly.
Peytons'z
May 6, 2021 09:25 AM
sbusaidi90
N2O Tech
Apr 22, 2015 06:51 AM
alphaauto
Jan 23, 2015 07:42 AM
Killer94z
Jan 13, 2015 12:06 PM
Mike Meyers
Aug 14, 2002 01:26 PM
