58mm?
Old Dec 3, 2006 | 12:17 AM
thegift's Avatar
58mm?
What gains would I get by replacing my 48mm stock throtle body with a 58mm? And which brands would you guys reconmend?
Old Dec 3, 2006 | 02:38 AM
RedsTA's Avatar
Any other mods to your car? With a 58mm you have to bore the intake openings to match the TB gasket. All depends on the other mods on what youlll gain from it.
Id go with bbk if you end up doing it.
Old Dec 3, 2006 | 03:24 AM
Gun5's Avatar
what gains do u think id get?? 5 hp or so?
Old Dec 3, 2006 | 08:28 AM
CrazyLT1's Avatar
With your mods, I would say AT LEAST 8-10 RWHP
That stock throttle body has gotta be chocking you, especially with already ported intake, heads,etc..
Old Dec 3, 2006 | 09:18 AM
chrism400's Avatar
That's probably close. I had a similar setup in mine and saw a proven 10 RWHP on the dyno going from a 48 to 52. There was a loss of 1 ft. lb. of torque. I'm not sure if the extra air from the 58 would help you, and it may hurt low end slightly. BBK by the way on tb choice.
Old Dec 3, 2006 | 11:13 AM
droptop z's Avatar
I did'nt do a before an after dyno, but once I installed the 52mm BBK throttle body, I could tell that it had alot more throttle response to it.
Old Dec 3, 2006 | 11:40 AM
2000GTP's Avatar
If you have a bolt-on or stock motor, you will see very little gains with a bigger throttle body. If you do decide to do it, having your stock throttle body ported is the cheaper alternative. Otherwise, you could buy an aftermarket one from Holley, BBK, ASM, and even Summit makes one.
Old Dec 4, 2006 | 10:46 AM
aaron_depue's Avatar
UI got the 58 mm tb and port mtched intake. I love it. Noticible power increase and that sucking sound that the intake makes is awsome. Sounds superchaged a little. IMO... get the tb and intake instead of just one. You wont regret it
Old Dec 5, 2006 | 11:37 PM
Gun5's Avatar
my intake was ported but not the TB holes I was thinking just do a 52MM since the holes are already that size would I have to get it retuned or is it not that much of a diff the computer should adjust?
Old Dec 6, 2006 | 12:24 AM
edman's Avatar
350 cubes verses 281 for a Stang
I think you can't go overboard even at 58mm because the new 'stangs are little bitty 281 cube motors and they have 55mm as stock. The hot rodders are increasing them to 62mm as far as I know. Are their cams and heads that superior that they need so much more volume than our Z28's? I don't think so.
Old Dec 6, 2006 | 12:30 AM
Gun5's Avatar
ya well i dont want to put a 58 due to not being ported for it so its gonna get resistance then... thats the only reason i guess it would make some shelf and hurt it more then u know help it but 48 > 52 should be a good increase i think a good 4-8 maybe 10 hp?
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
truecontr3
Oct 11, 2015 09:30 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
bunker
Aug 1, 2015 09:47 PM
