58m throttle body ,help or not
Old Nov 5, 2006 | 08:47 AM
itzkwik's Avatar
i have a 355lt1, ported heads ,cc306 cam 11.6.1 cr and runnig the dry nos system anyherer from 125- 200 shot. will a larger than a stock nicely cleaned up throttle body w/ air foil help all that much, I have heard they will give you bout 10 hp, too me tha t doesnt seem like 300-500 dollars.
Old Nov 5, 2006 | 08:50 AM
Guest47904's Avatar
Guest
On a 355, anything over 52mm is a waste.
Old Nov 5, 2006 | 09:49 AM
JP95ZM6's Avatar
Well, I don't claim to know firsthand, but when I talked LE2/LE1 supporting mods with Mr. Elliot, he recommended 58mm for my 350. Logic: If you upsize, any size costs the same, and he pointed out that in a fuel injected system throttle response does not suffer like it would in a carb application, where the fuel signal depends on air velocities. Made sense to me.
The only drawback I can think of is that the TPS resolution would effectively be reduced if full power/airflow occured at less than WOT, but I don't know how big a factor that is. So, even if the difference is minimal gains, why not? At least you would be 'futureproofed' a little in case you ever need more flow. FWIW.
Old Nov 6, 2006 | 06:54 PM
DrivingZiggy's Avatar
I called AS&M to get a Monoblade. But they advised against it for my 355, so I got the 58mm.
Old Nov 6, 2006 | 07:06 PM
kline454's Avatar
i gained 2mph in the 1/4 when i put my 58mm on.
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
