52mm TB or 58mm TB?!?!?58mm too big??
Old Mar 15, 2004 | 01:59 PM
  #16
detroit1994z28's Avatar
Re throttle body
Well lets just put it this way you get what you pay for. Holley has always been a better brand. Bbks are junk. I been asking almost every performance shop about BBK thorttle bodys they said they are junk, they break easy. Holley throttle bodys will run an extra 200.00 but trust me its worth every penny. If you get one get a 58mm. I have a stock lt1 and I have had no problems yet just a major increase in Horsepower. - MIKE
Old Mar 15, 2004 | 05:55 PM
  #17
triumph's Avatar
Well for the Money the holly sould be better. The blades tend to bind up and stick causing a high idle or stuck throttle.There are a few other quality issues as well. The only knock on the BBk is some of the older ones will whistle. Steven
Old Mar 16, 2004 | 07:20 AM
  #18
GreenbeanZ28's Avatar
I have a 58 mm Holley now, its pretty. Did have a TPIS 52 on a stock car (handful of bolt on's) and it picked the car up .2 and 2 mph in the 1/4. If I had to do it over again, I'd get a 58 even with just bolt on's....not like a carb ya know, cant over do it. TB just meters the amount of air coming in....
Old Mar 20, 2004 | 02:15 AM
  #19
Vendetta's Avatar
Just to add a note against the BBK 52mm TB, it is junk. I have one, and it's gotten stuck open twice already. I'm planning on replacing it with a Holley 58mm soon enough. I actually had to get out of my car, pop the hood, and the throttle was stuck in a position so that it was a bit off the pin, causing the motor to rev to about 2400-2600 RPM. It was pretty embarassing the first time, considering I was in the Burger King parking lot about to leave. I just fiddled with the throttle a second and it went back to place. I don't know what happened, but it's happened once about a week later and not since then... that was around sept or oct.
Old Mar 20, 2004 | 04:36 AM
  #20
FormulaLT-1's Avatar
well ya'll have me feeling better about the holley I just purchased, I did hear they had some problems with the TPS not reading right on some though. I guess it is a easy voltmeter/drill mod and it is fixed.
truecontr3
Oct 11, 2015 09:30 AM
95blkss
Sep 22, 2015 03:18 PM
Sep 18, 2015 03:46 PM
colts0455
Sep 2, 2015 12:41 PM
NewsBot
Aug 3, 2015 02:40 PM
