52mm to 58mm throttle body
Old Jan 29, 2006 | 11:32 PM
jay973's Avatar
do you have to port your intake when you use a 58mm throttle body i mean the stock holes for your throttle body how big can you go with stock throttle body openings?
Old Jan 29, 2006 | 11:33 PM
blazzinbird's Avatar
Re: 52mm to 58mm throttle body
yes you have to open them up to a 58mm size
Old Jan 29, 2006 | 11:35 PM
jay973's Avatar
what about 52mm
Old Jan 29, 2006 | 11:49 PM
LT1 EXPRESS's Avatar
Or u can just by my intake and throttle body yout injctors and map and bolt it on http://members14.clubphoto.com/micha...48/guest.phtml
Old Jan 30, 2006 | 12:03 AM
Chrisbequick's Avatar
You can run up to a 54 on an unmodded intake.
-Chris
Old Jan 30, 2006 | 02:00 AM
The Engineer's Avatar
Send me a PM with your e-mail address and I'll send you some photos of how to neatly machine-out (not grind) at home the intake venturas to 58mm.
Old Jan 30, 2006 | 04:09 AM
jloshotz's Avatar
I just bought a 1995 M6 Z, it has a 58mm TB. If you do not open the venturis, will the blades even open correctly? Just curious if it is a fitment issue or an issue with proper function otherwise....
Old Jan 30, 2006 | 09:04 AM
96capricemgr's Avatar
The blade will open correctly but this probably wouldn't flow any better than the stock setup as the smaller intake bores will provide a signifigant restriction to CLEAN flow. Even a 52 is a waste on a stock engine though so you might consider going back to stock.
Potent77
Mar 16, 2022 12:13 AM
oldschool
Feb 9, 2016 09:21 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
