52 mm TB s
Old Aug 18, 2003 | 09:27 PM
97silverz28's Avatar
52 mm TB s
Anybody know if there are any other makers of the 52 mm TB besides BBK?
Old Aug 18, 2003 | 09:29 PM
Josh-'04 GTO's Avatar
Edelbrock was making them, as well as a host of people overboring stock cores such as Arizona Speed & Marine and TPIS.
Old Aug 18, 2003 | 09:36 PM
NOMAD's Avatar
Cool
I make em from stock cores
-Shannon
Old Aug 19, 2003 | 06:02 AM
revtime's Avatar
Holley was making them the last I checked.
Old Aug 19, 2003 | 10:03 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
i really dont think you need one and its money better spent in other places unless its from nomad and he still has his low prices.
Old Aug 19, 2003 | 12:52 PM
BUBBA's Avatar
Go with Nomad or AS&M. I understand Holleys can have minor problems. JMHO
Old Aug 19, 2003 | 01:27 PM
LT4POWR's Avatar
-Shannon
How much?. Do they come w/ a built in air foil or can you use a 48mm air foil? Thanks
Old Aug 19, 2003 | 03:46 PM
Trey,
$$ better spent elsewhere. Where? I'm open to suggestions. Headers & Nos are not options though.
Old Aug 19, 2003 | 03:53 PM
atljar's Avatar
His dont come with airfoils, but if you have a 48mm air foil he can make it fit very well. Im very happy with mine i bought through him
Old Aug 19, 2003 | 03:57 PM
treyZ28's Avatar
Originally posted by 97silverz28
Trey,
what are they $300?
gears (+ install), springs, shocks, midget ****- almost anythign for $300. clean your airfilter and call it good. Unless its shannons and for better throttle respose or a built to ***** motor- its pretty worthless.
muffler? high flow cat? SFC, LCA, cam? rockers? K members, drag radials?
Old Aug 19, 2003 | 04:04 PM
Maybe gears, but the gears + install will run alot more than $300. You can keep the midget **** & your suggestions.
Old Aug 19, 2003 | 04:20 PM
treyZ28's Avatar
dont tell me i didn't warn you.
while your at it, grab an air foil, tornado a pair of cross drilled rotors, 8ft spoiler and a hypertech programmer
edit: dont forget the graneteli Maf
Old Aug 19, 2003 | 04:44 PM
Or maybe I can get a LT-4 engine.
Old Aug 19, 2003 | 06:40 PM
treyZ28's Avatar
it appears to me that you know not what you speak of?
Perhaps you were trying to sarcastically and humeriously point out that the modifications I suggested were out of your price range?
what are they $300?
gears (+ install) $300 + install
Springs- Less than $300
shocks- varry fom $100- thousands
midget ****- it was a joke, as in anything would be better as per the next line " almost anythign for $300"
clean your airfilter and call it good.- ie, it will gain the same results
Unless its shannons and for better throttle respose or a built to ***** motor- its pretty worthless. self explanitory
muffler?- $100
high flow cat? $250
SFC, $150
LCA, $200
cam? $275
rockers? $275
K members, No clue, probobly around $300
drag radials? about $300
So why the sarcasm? none of the mods i suggested were really above $300... all would provide better results.
Old Aug 19, 2003 | 11:34 PM
fireman's Avatar
I had my stock TB bored to 52mm at my local machine shop, bought 52mm blades from AS&M.
Machine shop-$100
Blades from AS&M-$25
I have had no problems at all.
