52 mm TB s
Originally posted by LT4POWR
How much?. Do they come w/ a built in air foil or can you use a 48mm air foil? Thanks
Originally posted by 97silverz28
Trey,
$$ better spent elsewhere. Where? I'm open to suggestions. Headers & Nos are not options though.
Trey,
gears (+ install), springs, shocks, midget ****- almost anythign for $300. clean your airfilter and call it good. Unless its shannons and for better throttle respose or a built to ***** motor- its pretty worthless.
muffler? high flow cat? SFC, LCA, cam? rockers? K members, drag radials?
Maybe gears, but the gears + install will run alot more than $300. You can keep the midget **** & your suggestions.
while your at it, grab an air foil, tornado a pair of cross drilled rotors, 8ft spoiler and a hypertech programmer
edit: dont forget the graneteli Maf
Or maybe I can get a LT-4 engine.
Perhaps you were trying to sarcastically and humeriously point out that the modifications I suggested were out of your price range?
what are they $300?
gears (+ install) $300 + install
Springs- Less than $300
shocks- varry fom $100- thousands
midget ****- it was a joke, as in anything would be better as per the next line " almost anythign for $300"
clean your airfilter and call it good.- ie, it will gain the same results
Unless its shannons and for better throttle respose or a built to ***** motor- its pretty worthless. self explanitory
muffler?- $100
high flow cat? $250
SFC, $150
LCA, $200
cam? $275
rockers? $275
K members, No clue, probobly around $300
drag radials? about $300
So why the sarcasm? none of the mods i suggested were really above $300... all would provide better results.
