42lb injectors??? advice
Old Dec 18, 2003 | 02:25 PM
96ta(nick)'s Avatar
comp 306/ported heads/ etc. Are 42lb injectors overkill? will they work ok for my app?
Old Dec 18, 2003 | 08:22 PM
superjerry's Avatar
Those are overkill. 30's would work, 36's would be better if you want lots of power in the future.
Old Dec 18, 2003 | 08:40 PM
Josh-'04 GTO's Avatar
Re: 42lb injectors??? advice
I agree with superjerry in regards to the overkill opinion.
Since those injectors are a solid 30% bigger than what you need, they will be way too rich at low RPM, but you can band aid that through tuning. The best way to go is with the right size injectors from the start.
Firechicken350
Jun 6, 2015 11:25 PM
z28cam1993
May 29, 2015 10:17 PM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
SC97TA
Sep 15, 2002 01:10 AM
