425 RWHP on a 396?
425 RWHP on a 396?
I am in the middle of putting together all the parts for a forged 396 and need opinions of people more knowledgeable than me in this engine. It will need to be mostly street with some track in the summertime.
List of parts:
-forged eagle crank, 6" rods and SRP -7cc flat top pistons (already bought)
-decided on LE3 H/C combo with port matched intake (saving money for)
-Jet-Hot LT's with ORY (already bought) plus I have a Borla on the car already and like the sound
-MSD 6AL, MSD coil and MSD 8.5mm wires, or would the Delteq be better? I might even be willing to try to MSD cap and rotor for the Opti if I go with the MSD setup
-Walbro 255 with Delphi 42# injectors
-AS&M monoblade
-Spec stage 3
-aluminum driveshaft
-moser 12 bolt with 3.73 gears if 4.10's wouldn't be to much
also I would like to run a 100 shot of juice, mostly for track purposes, or a stray Honda. Any other suggestions are welcome.
List of parts:
-AS&M monoblade
-Spec stage 3
Re: 425 RWHP on a 396?
Originally Posted by SStrokerAce
500hp + gotta spend some time on tuning that thing and you should be good.
Bret
Bret
Guest
Posts: n/a
A friend has a identical 396 to mine and he puts 420hp down with a stick and a 230/236 XE cam, so the LE3 cam combo should put down more as it is more aggresive than a 847 cam. I put 400rwhp down with the Hot Cam in my 396, awaiting a data cable to dyno with wideband, and will have numbers for my 396 with XE 230/236 with an 4L60.
yeah, this altitude ticks me off sometimes. I'm mostly wanting opinions as to how this setup will work together so I don't buy a bunch of parts and end having to buy other stuff because these aren't compatible for my goals.
I'm not enough of a nitrous guru to know for sure, but I find myself asking the question; "Is 42lbs enough if I'm going to use a dry shot?"
I'm thinking in terms of supplying a very healthy 396 PLUS a dry shot, and of course you could easily decide that 200 sounds groovy too. Your engine combo certainly sounds as if it's up to it.
You may want to pose that specific question in the nitrous forum, and since 42lbs is already getting big for High-Z injectors, you MAY want to consider getting that converter that lets you run Low-Z injectors and getting yourself a set of those injectors, perhaps in the 50-60lb range.
UNLESS of course you go wet.
Anyhow, this may be my over cautious side and the guys who REALLY know what they're talking about may very tell you that 42lbs is fine.
BTW, sounds like a sweet engine. I'm quite jealous.
Guest
Posts: n/a
Originally Posted by Compstall
He's sitting at 5500 elevation, ain't gonna happen N/A. He could get close though. I met a guy here that had a similar combo to what you have there a while back and only made 360 at the wheels N/A. Altitude sucks.
I know when I went and climbed to the continental divide at 12.5k in Colorado I couldnt believe the difference in air, or lack of. At Bandimere, you have to feel sorry for the guys running there as there times dont correlate to the real times of at sea level.
OOPs, did not realize this. Do the Dynos correct for elevation? Or do we have to calculate it ourselves.
using a fuel injector calculator with 43.5psi fuel pressure and 80% duty cycle the 42# injectors should handle about 600 HP
I moved here to Albuquerque from Seattle a little over a year ago. I have first-hand experience in what altitude does to an N/A motor. I lost 54 hp and 64 lb ft of torque, 1.2 seconds in E.T. and 7 mph in my trap speed.
Dyno shops at or near sea level don't talk a whole lot about corrected numbers like they do in places that are at high altitude because the numbers are usually pretty close to each other. When you're at high altitude, you see a HUGE difference between what you're actually putting down and the "corrected numbers".
