410rwhp from LE heads and 847... (graph inside)
Old Jul 21, 2004 | 01:06 AM
reuter's Avatar
well, got the car tuned up good today down at Carolina Auto Masters. If youre on the East Coast, they are the absolute place to go. The car dynoed good, but what sucks is that there is some valve float or valve spring failure going on at ~6100RPM. it should have kept pulling hard up top all the way to rev limit at 6500RPM so i definitely got shorted some power, but it's all good. im goin to contact Lloyd tomorrow to see what springs are on these heads. if its not the springs i'm gonna have to go in and see just what the hell is goin on. i also blew a damn header gasket 2 days before tuning. but anyways back to what yall wanna see
mods are LE heads, 1.6RRs, LTs (cutouts not installed yet), 847 Cam, CSI, BBK TB, K&N FIPK, SLP 2OTL Exhaust
once i get this valvetrain issue worked out i'll have it redynoed. this time with two 3" cutouts gettin rid of that gas and no more massive exhaust leak from cylinder #1. all numbers are SAE corrected. enjoy
Old Jul 21, 2004 | 01:42 AM
Silvershark's Avatar
Re: 410rwhp from LE heads and 847... (graph inside)
Nice results! LE2 heads I assume.
Old Jul 21, 2004 | 01:52 AM
J's 82's Avatar
CAM is a great place, Jeff spent fours hours and eleven pulls with my car when I was there..
your graph looks very much like mine only more power!! got to get rid of my edelcraps.. !!
nice numbers!
Old Jul 21, 2004 | 01:58 AM
ibanez6rg's Avatar
Very nice!
Old Jul 21, 2004 | 05:32 AM
1982z28with18s's Avatar
Looks good, Lloyd comes through again. Now get some track times.
Old Jul 21, 2004 | 08:05 AM
Fastbird93's Avatar
Nice numbers......looks to me like you may have a few hp left on the table though, as your A/F looked like it was hovering right around 14 throughout the powerband.
Old Jul 21, 2004 | 08:06 AM
LT4POWR's Avatar
Good #s.
What injectors and lifters are you using?
Old Jul 21, 2004 | 09:23 AM
quicksilver97ta's Avatar
Nice numbers, congrats.
I see your higher hp#'s were on a leaner pull. I've heard it before, "lean is mean". LOL
Hows the drivablilty on that 847? any cam surge?
Old Jul 21, 2004 | 09:28 AM
truedualws6's Avatar
Very nice numbers! If you find that you do have valve spring issues you may
want to consider the Comp beehive springs. The 26918s would probably solve
your problems. It's most likely that your heads are already machined for larger
springs though.
Old Jul 21, 2004 | 09:31 AM
xxsaint69x's Avatar
is that thru a 12 bolt?
Old Jul 21, 2004 | 09:40 AM
reuter's Avatar
i took it to the track untuned and trapped 111mph with an inconsistent, extremely rough 381rwhp. it should run A LOT better now. the car feels totally different.
30 lb injectors and Comp R Lifters
jeff tuned it to have extremely good street manners. it really runs excellent now. pretty much no cam surge.
and its through a 10 bolt with 4.11 stranges in there
Old Jul 21, 2004 | 09:49 AM
xxsaint69x's Avatar
can you send me your lt1 file..i want to take a look at your 400-4000 spark adavane tables.
Marcin
Old Jul 21, 2004 | 09:53 AM
RealQuick's Avatar
Nice!
Old Jul 21, 2004 | 09:56 AM
R8E1D's Avatar
Hey reuter Pm me and let me know how much that dyno tune put you back I should be getting mine out of the shop tommorrow and after the break in thats where IM headed! thanks
Just found a clip of your car on tidewater sounds kick***.
Old Jul 21, 2004 | 11:31 AM
WhiteSSP's Avatar
Nice Reuter! I think you've just made up my mind as to who I'm going with when I start to really do some work to my Formula. Thanks. Still going to the track this saturday?
