400+rwhp with a hotcam or xe224/230?
Old Jul 12, 2004 | 11:52 PM
  #16
1982z28with18s's Avatar
I dyno'd 384rwhp before tuning with a 220/226 Joe O. cam and Lloyd Elliot heads. It should be right at 400rwhp now with tuning. I'll hit the dyno again in a few weeks when the new tranny goes in.
Old Jul 13, 2004 | 01:30 AM
  #17
BadAssed93Z's Avatar
well i was all but decided to go bigger before i posted my reply,
and now i have decided.
so anyone want to buy a 224/230 comp cam? Pm me if interested.
Old Jul 13, 2004 | 01:36 AM
  #18
Somnambulist's Avatar
what sort of springs would be good for 1.7's and the 224/230?
Old Jul 13, 2004 | 04:14 AM
  #19
dhirocz's Avatar
Comp 987's would work fine but need machining. I like bigger springs because they're more stable at higher RPM and an equivalent single or smaller diameter spring. But opening up the spring pockets and crap on heads can be a PITA is you aren't equipped for it.
Combination motorsports sells a spring that drops right in that should work fine. But I'm pretty sure the Comp 987 is good up to .600" lift. Dunno about the CM spring.
Old Jul 13, 2004 | 05:05 AM
  #20
Fastbird93's Avatar
Thinking about giving it a shot????
I'd just say to call comp or crane or whoever you want to buy springs from and ask them directly what the recommendation would be. Preferably comp because of their familiarity with the cam and the ramp rates on the lobes.
Old Jul 13, 2004 | 02:01 PM
  #21
well i just sold off a set of ex612's and brand new lifters in order to finish with some suspension and appearance stuff...
when i finally go with a cam ill be keeping my heads stock and tossing in a decent cam (probably the 224/230) Maybe ill add some 1.7's as well...couldnt hurt
Old Jul 13, 2004 | 02:26 PM
  #22
formula383's Avatar
Comp will probably suggest the beehive springs. They are a little more expensive than regular springs though.
Old Jul 13, 2004 | 07:35 PM
  #23
mastrdrver's Avatar
Thats what I would suggest. A little better valve control. It has been proven they provide power increase over the conventional comp springs. But, I would talk to Comp first, CM, or someone who has an idea about them and that cam with 1.7s.
Old Jul 13, 2004 | 09:21 PM
  #24
bunker's Avatar
Prolly cuz of the smaller diameter retainer keeps the valve train light weight.
Old Jul 13, 2004 | 10:48 PM
  #25
pillagenburn's Avatar
springs for 1.7rr's
just wondering if there are any springs you could use wiht 1.7rr's that wouldn't require head machining - any ideas?
thanks
Old Jul 14, 2004 | 12:14 AM
  #26
JodyJ's Avatar
Sent you an e-mail on your cam.
Thanks,
Jody J.
Old Jul 14, 2004 | 08:53 AM
  #27
formula383's Avatar
I don't think the beehive springs require any machining.
Old Jul 14, 2004 | 09:11 AM
  #28
ok, i was thinking some AFR 210 or 220cc bare heads and MAYBE a mild port job on them. I believe this as a budget-minded setup would be pretty effective with a comp XE 227/233 cam (cmotorsports). Maybe revving to 6500rpm would really open it up on a stock-ish displacement car. The idea is to make 400+rwhp while keeping near-factory displacement.
ideas?
thanks
oh yea - this is all on 1.6 roller rockers
Old Jul 14, 2004 | 09:32 AM
  #29
LT1ponykilla's Avatar
Theres a few guys on AI site with the GM847 cam, AI econo port heads, shorty headers, catbacks, and other bolt ons making 405rwhp.
Old Jul 14, 2004 | 09:51 AM
  #30
Just get the le2 package from Lloyd Elliot. It'll be a lot cheaper and should give you 400rwhp.
