400 horse power
Old Mar 31, 2007 | 10:35 AM
  #16
sworaz
Guest
Posts: n/a
Originally Posted by 95Z28ConvtM6
And then there is the "while I have it apart" syndrome!! Figure out what you hope it will cost and double it!
lol, I sure do hate that! Told the wife it was going to cost around 2,800 turned out to be about 4,800,
Old Mar 31, 2007 | 01:00 PM
  #17
97WS6SCharged's Avatar
You would be better off just spraying a 100 shot if you wanted quick and easy.
Old Mar 31, 2007 | 03:12 PM
  #18
pyro719's Avatar
a 100 shot it is! I already have the kit. Oh I used to have a taurus sho and bought a walbro 155lph pump for it, Will it fit my Z?
Old Mar 31, 2007 | 03:14 PM
  #19
396D1SS's Avatar
Originally Posted by zx1216
wooooa, there are a lot of small things here and there you are leaving out, your going to run that cam on the stock springs??? locks/retainers, timing set, guideplates, pushrods, gaskets...
thanks for the correction, I cant believe i forgot to mention those
Old Mar 31, 2007 | 05:04 PM
  #20
2000GTP's Avatar
I may be wrong, but I believe that the stock pump on the f-body is a 190lph rating. That right there would make the SHO pump incompatible and that is assuming that the dimensions are exactly the same, which I would venture to guess they would not be. A Walbro replacement pump for your 4th gen will run about a 140 bucks, maybe a little cheaper depending where you shop.
Old Mar 31, 2007 | 08:59 PM
  #21
pyro719's Avatar
Any one know what the stock 94 z28 pump is? 190lph sounds excellent for a stock pump. And the dimensions on the pumps are identical.
NewsBot
May 16, 2015 04:00 PM
cobrakilling101
14
Mar 17, 2015 10:42 AM
94Z28LS1toLT1
Mar 10, 2015 09:52 PM
XtremeLt1
Sep 13, 2002 08:50 PM
