400 crank in LT1
Old Sep 24, 2003 | 06:40 PM
Zrag's Avatar
400 crank in LT1
Planning winter project of 383 build up. Ported heads, XE 230/236 114lsa or 112 and current mods listed below.
Question is I got my hands on a 400 crank not sure of year. How can I tell? Can I use it in my LT1?
Yes it would be taken to the machine shop for balancing etc...
Please let me know. thxs
Old Sep 24, 2003 | 06:50 PM
AndyB's Avatar
A 400 crank will work if you buy an adapter for the two piece seal crank.
IMO just buy a new Scat 3.75 cast crank. They are only a coule hudnred bucks and wont require an adapter. There are plenty on ebay
Old Sep 25, 2003 | 10:40 AM
Zrag's Avatar
Ok so how much is the adapter?
And is that the only mod needed besides case clearence issues?
Thx
Old Sep 27, 2003 | 06:28 AM
quickSS's Avatar
I have a cast 400 crank in my LT1 383 and the adapter for the 2 piece rear is more than $100 bucks. I cannot remember. Something like $120 or thereabouts. I just called Dal and had him send it and didn't pay attention to the price like I should have.
That's why, just like mentioned already, I should have just purchased a cast 1 piece rear scat crank and saved money in the long run.
Karl
Old Sep 27, 2003 | 07:44 AM
Timberwolf's Avatar
doesn't the 400 have larger main journals that need to be cut down too?
Old Sep 27, 2003 | 08:13 AM
anaik's Avatar
Correct, has to be cut down to 2.45" from 2.65".
Old Sep 27, 2003 | 03:01 PM
SStrokerAce's Avatar
Yep, after the adapter and having the main journals ground down to the right size you are going to spend more money on a used stock crank that is less of a piece than a Scat 9000 crank and it's going to cost more to balance. Hmmm wonder which one I would do?
Bret
Old Sep 29, 2003 | 03:17 PM
Zrag's Avatar
Thanks guys. That is something to think about. I may just consider to do heads/cam then. No matter though a 400 crank is a 400 crank thus more than 375.
thx
Old Sep 29, 2003 | 03:38 PM
Zrag's Avatar
thx
Noer
Feb 28, 2015 11:29 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
1LEThumper
Jul 14, 2003 12:45 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
