4 qts. of oil for 6spd...correct?
Old Jun 13, 2003 | 11:48 AM
94 CAMRO Z28's Avatar
Question 4 qts. of oil for 6spd...correct?
Just changed my oil in the tranny yesturday and I used 4qts. of Mobil 1 synth. I just wanted to make sure that was the correct amount. Im about 99.9% sure it is but even after 4qts. there still wasn't any spilling out like I thought it would. Although the car was jacked up on that side so I could lay under there. Anyhow, just wanted to make sure.
Aaron
Old Jun 13, 2003 | 01:57 PM
jim88iroc305's Avatar
Cool
8 pints
2 pints = quart
4 quarts should do it!
Old Jun 13, 2003 | 03:43 PM
BigRich's Avatar
jacking up only 1 side when changing M6 fluid will alter the full level.
better to use 4 jack stands under the frame so the car is level.
rear diff fluid change also
oh yeah, i couldn't get all the 4 quarts in, about 3.8 went in, so maybe you overfilled yours by .2 quart
Old Jun 13, 2003 | 03:52 PM
Zepp's Avatar
Yes. 4 quarts (8 pints) is correct.
Old Jun 13, 2003 | 04:54 PM
jwade95Z's Avatar
"jacking up only 1 side when changing M6 fluid will alter the full level. better to use 4 jack stands under the frame so the car is level. rear diff fluid change also oh yeah, i couldn't get all the 4 quarts in, about 3.8 went in, so maybe you overfilled yours by .2 quart"
I changed mine a couple of weekends ago, same experience. Level on 4 jackstands, didn't quite take all four before it starting to trickle out the fill hole.
Old Jun 13, 2003 | 06:00 PM
Laymaster's Avatar
I believe the manual calls for 3.8 quarts.
Old Jun 13, 2003 | 09:35 PM
Ok sounds good, Im guessing the .2 extra isn't going to hurt anything. I've heard of some who have just poored it in from up top. Thanks
Aaron
Old Jun 14, 2003 | 01:37 PM
Laymaster's Avatar
Aaron
I did that, it's so much easier that way....
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
