4 bolt mains???
Old Mar 30, 2006 | 09:29 PM
TRYTOTEST's Avatar
4 bolt mains???
I got a 2-bolt main LT1
I want to make it 4-bolt for my 396 buildup.
The block is already at the shop. What do I need to make it a 4-bolt?
Old Mar 30, 2006 | 09:54 PM
Josh'95Z28conv's Avatar
Re: 4 bolt mains???
4 bolt caps, and some machine work.
Old Mar 30, 2006 | 11:25 PM
rskrause's Avatar
Moderator
Re: 4 bolt mains???
Tell the machine shop "I want 4-bolt mains", specify OEM iron 4-bolt caps or aftermarket steel caps. It's not a DIY job and not cheap either.
Rich
Old Apr 1, 2006 | 07:19 AM
bvmwmike's Avatar
Re: 4 bolt mains???
get a block from a corvette
Old Apr 1, 2006 | 09:59 AM
LiENUS's Avatar
Re: 4 bolt mains???
And hel'l end up with 4 bolt straight, which is in many cases weaker than 2 bolt mains. A 2 bolt main block converted to 4 bolt splayed with a stronger aftermarket cap is a better choice.
Old Apr 1, 2006 | 10:11 AM
edunegan95's Avatar
Re: 4 bolt mains???
i was going to do splayed mains on my two bolt 383 my machinist said he had seen some blocks spider web do to the stress of splayed mains he suggested two bolt studs holding together so far
Old Apr 1, 2006 | 10:46 AM
94EvilZ28's Avatar
Re: 4 bolt mains???
Depends...how much RPM are you going to be spinning at...if its turning over 6500rpm, the go 4 bolt...but the 2 bolt will hold. Its not the power that screws the bottom end...its how fast you turn it that causes it to go out.
Old Apr 1, 2006 | 02:34 PM
Josh-'04 GTO's Avatar
Re: 4 bolt mains???
Splayed 4-bolt is the only way to go IMO...
Old Apr 1, 2006 | 03:44 PM
96capricemgr's Avatar
Re: 4 bolt mains???
The LT1 block is not a gen1 block and was designed with 4 bolts in mind, a good shop might have noticed or known that. That said the stock 2 bolt can hold a lot stud it and it will hold even more, the next logical step is the splayed 4 bolt with aftermarket caps, no sense in paying a premium for the Vette block, when that money could be put instead towards the better aftermarket setup, especially if you are genuinely going to need such a mod.
Old Apr 1, 2006 | 04:37 PM
FastZinTennessee's Avatar
Re: 4 bolt mains???
True story.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
maybe2fast
Mar 13, 2015 11:48 AM
pimpss96
Feb 12, 2015 01:28 PM
97 RedSS
Jun 10, 2003 07:58 PM
