4 Bolt Main Cap Info needed inside
Old Aug 2, 2006 | 05:30 PM
snakeatinZ's Avatar
I need to know what a good 4 bolt main cap is to go with. The motor is stock 350 ci. I am going with 4 bolt mains because it is going to be a spray motor. Should I go with Eagles Splayed 18 degree or GM LT4 style? Also, what kind of main bearings and piston rings should I go with?
Thanks,
Steve
Old Aug 2, 2006 | 07:06 PM
SStrokerAce's Avatar
Re: 4 Bolt Main Cap Info needed inside
Do a search on main caps, you will find a ton of answers for this.
Bret
Old Aug 2, 2006 | 08:49 PM
snakeatinZ's Avatar
Bret
Wow I found hours of info.... I have decided that the 2 bolt mains will work fine for me. But what kind of main bearings do I need to buy?
Steve
Old Aug 3, 2006 | 09:52 AM
That depends on the crank and the corner radius of the journals. A .093-.125 corner radius will use a Clevite H series bearing. Stock cranks can use this as well, but a bearing with less of a angle on the edge of it will work better. This is why Clevite has different series of bearings.
Bret
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
97 RedSS
Jun 10, 2003 07:58 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
