4 anyone interested in SLP LT4 clutch....inside
Old Mar 19, 2003 | 11:58 PM
96LT14u2Nv's Avatar
well, i have had my slp lt4 clutch in for about 6 months and have made about 15 passes on it up until saturday (all on drag radials). well saturday i was cutting real low 1.9 60's on ET streets. after getting home and watching the tape, i can see some smoke on every run from the tranny. and driving the car on the street i can definately tell that this clutch is SLIPPING BAD! so, anyway, just thought i should share my experience since clutch ?'s are pretty common on here. i mould highly recommend running this clutch for street use but if u want to run on some sticky tires....get someting else. i, myself, am going with a ram clutch and adjustable slave cylinder. i will let u know how that turns out.
Old Mar 20, 2003 | 08:33 AM
LT4POWR's Avatar
Thanks for the info
Old Mar 20, 2003 | 08:53 AM
GREGG 97Z's Avatar
I made 30 passes on mine last year on Nitto DR's with no signs of slipping, clutch held up fine and ran plenty 1.9x 60' and 13.0x's with a few 12.9x's. I think it was the ET streets that killed yours, this clutch is not strong enough for that kind of traction you were getting. If the tires don't slip a little on the launch something else is going to give.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
97FormulaWS-6
Sep 11, 2002 11:57 AM
97FormulaWS-6
Aug 5, 2002 05:15 AM
