4.88s in a 6spd
Old Feb 17, 2004 | 03:23 PM
hot936spd's Avatar
4.88s in a 6spd
anybody tried 4.88s in a 6psd??? if so, let me know, how you liked it
Old Feb 17, 2004 | 03:25 PM
Kain's Avatar
I doubt anyone around here has that high of a rear-end gear ratio. The highest I've ever seen is 4.56's for the stock 10 bolt anyway, and then the teeth are way too thin.
Old Feb 17, 2004 | 03:27 PM
Hawk350's Avatar
You would never grip....
Old Feb 17, 2004 | 03:28 PM
atljar's Avatar
Ive got 4.33, and ive seen one or two with 4.56.
Most of the 6 speed guys go with 410s
Old Feb 17, 2004 | 05:30 PM
Got-LT1's Avatar
Seen several 4.56s (one was even in an a4 ), but never a 4.88 in the stock 10bolt anyway.
Old Feb 17, 2004 | 07:33 PM
hot936spd's Avatar
i should have just said that, i have a m26 93 6spd, and it has lower gear ratio than 94 in up 6spd, so if i put 4.56s in it, i would be little like 4.88s. cause i had 4.10s and rpms were same as my friend with his 4.56s. just wondering
Old Feb 17, 2004 | 09:06 PM
my94blackz's Avatar
That would be to much gear. Either that or run a cam that pulls to bout 7500 then it would be sweet. I thought one guy said he was runnin what was it 4.70's in a 9 inch? oh well i cant remember.
Old Feb 17, 2004 | 09:15 PM
My95Z's Avatar
i have 4.10's and they are perfect. I think anything higher would just be too much
Old Feb 17, 2004 | 09:47 PM
ibanez6rg's Avatar
That ratio would be steeeep!
Old Feb 17, 2004 | 09:54 PM
KCFormula's Avatar
Do you mean the M29? If so the 1st gear is the only one that should be really steep. The gears will get gradually closer as you go to 4th. (4th is always a 1.00:1 gear for all Fbody 6spds) The M29 is just not as close ratio as the regular MN6.
Old Feb 18, 2004 | 09:00 AM
IDOXLR8's Avatar
Are you setting your car up for the 1/8th mile?
Old Feb 18, 2004 | 11:21 AM
95Bird's Avatar
I run a 4.71 gear(9" rear end), a 28x10.5 et drag and can spin up to 7000 rpms. Unless you can do the same your gonna run out of gear way before the 1/4 mile.
With a stock size tire a 4.88 final ration on a 1:1 4th gear is good for 99 mph at 6300 rpms.
Camarokid95
Jun 12, 2015 11:25 PM
TYLER94Z28
Dec 3, 2014 07:05 AM
ut
Aug 20, 2003 09:28 AM
turbo_Z
Jun 10, 2003 02:45 PM
tonyss1
Apr 16, 2003 08:22 AM
