4.88s in a 6spd
i should have just said that, i have a m26 93 6spd, and it has lower gear ratio than 94 in up 6spd, so if i put 4.56s in it, i would be little like 4.88s. cause i had 4.10s and rpms were same as my friend with his 4.56s. just wondering
I run a 4.71 gear(9" rear end), a 28x10.5 et drag and can spin up to 7000 rpms. Unless you can do the same your gonna run out of gear way before the 1/4 mile.
With a stock size tire a 4.88 final ration on a 1:1 4th gear is good for 99 mph at 6300 rpms.
turbo_Z
Jun 10, 2003 02:45 PM
tonyss1
Apr 16, 2003 08:22 AM
), but never a 4.88 in the stock 10bolt anyway.
